WebUI unable to move Files
cosmicTech
Post by cosmicTech »
So I'm having a major issue with the WebUI. When I attempt to move files from it I get an access denied message. However when I attempt to use the client itself I am able to move the files without issue (or at least I assume so since I have not gotten an error when attempting to do so).
cosmicTech
Re: WebUI unable to move Files
actually! after checking it seems that the client hasn't moved the file even when using the "set location" button as was advised on other forum posts! what's the proper way to move a file that I've downloaded and continue to seed it?
hatless
Post by hatless »
cosmicTech wrote: Wed Nov 13, 2024 10:53 pm So I'm having a major issue with the WebUI. When I attempt to move files from it I get an access denied message. However when I attempt to use the client itself I am able to move the files without issue (or at least I assume so since I have not gotten an error when attempting to do so).
I'm seeing similar behavior, no error message with the WebUI (qbittorrent-nox) but the files aren't moving. If we think this is a bug, I can report or comment wherever I'm supposed to.
Thank you
hatless
Post by hatless »
hatless wrote: Wed Feb 26, 2025 5:05 pm
Thank you
And just a few minutes later, it is working. I am guessing my server was bogged down by something perhaps.
