Piratebay/https://thesurferprotector.com/?67c0c80be9b42
- Newbie
When ever I use Piratebay for searches, every other command I make results in, in addition to my piratebay window, my getting a window from thesurferprotector.com noted in the subject. It doesn't matter if my VPN is on or not. I can go back to the PB window and enter in the next step but when I enter another command like going to a search result, it results in another surferprotector window opening, which I can ignore and go back to the PB window and enter the next step, but I end up with a ton of unneeded windows open or having to close them each time. Any ideas?
Re: Piratebay/https://thesurferprotector.com/?67c0c80be9b42
I'd just use a proper adblocker like uBlock Origin.
But this is a common complaint:
https://www.reddit.com/r/ThePirateBays/ ... protector/
