Hi everyone,
I've tried to run most of the appimages for 5.0.x and they don't do anything. 4.6.7 still works fine, but I was hoping to upgrade to the newer version. I'm on Debian 11 and have made the file executable. I made sure no other versions of qbit are running.
Does anyone have advice on this?
Appimages of Version 5 won't run
Re: Appimages of Version 5 won't run
I suppose Debian 11 is too old; Debian 12 has been out for a while.
(this is just a theory but I'd definitely try it on Debian 12 if you can. at least a virtual machine or something.)
You are correct. Upgraded to 12 and it works great. Thanks!
