that's a long topic name. is there a way to configure qBittorrent in a way that it always retains any torrent for 4 days first, even if the ratio went over 100.0, but then keep seeding it after four days but only until the ratio reaches a hundred? then remove torrent and it's files.
i currently have it set up to 5760 min, but i can't enforce a ratio limit without potentially affecting the minimum time
seeding limits for a certain ratio but only after total seeding time reached a certain time, never before that time
- Newbie
Re: seeding limits for a certain ratio but only after total seeding time reached a certain time, never before that time
Just write a simple script using the API or the python library that uses the web API.
