Copy *.torrent files from old computer to new one
hcour
Post by hcour »
I have a new computer and I'd like to copy some of my torrents from the old system to the new one to seed. The folder I need to copy the files to is the qbittorrent BT_backup folder in appdata/local, correct?
Also, as long I have qbit pointed to the correct folder where the downloaded media files are stored, it won't automatically start re-downloading, correct?
Thanks!
Re: Copy *.torrent files from old computer to new one
Ugh its complicated (a bit).
- Bt_Backup has like old files too.
- I'd set up the new qB with the download folder
- then bulk add and let them re-check
