So i been trying to fix this for a few months and nothing has worked so far if i try to run any version newer then 4.67 it the client freezes and locks up, needing to be end tasked nothing is downloading either once it freezes so its not just a gui issue any help is welcome system specs below. Thins iv tried is do a full clean install remove all other files i could find in both APDATA folders and install a fresh copy with reset settings and not change anything and it still freezes.
Windows 11 24H2 26100.3775
CPU is a 9950x
48gigs of dd5 8000
att fiber thru a nordvpn
QBittorrent 5+ freezes
Re: QBittorrent 5+ freezes
hello anyone got any ideas heres the reddit post i did also where i tried quite a few things.
https://www.reddit.com/r/qBittorrent/co ... 5_freezes/
Replied.
