After updating from v5.0.5 to v5.1.0 I don't like the new colors
sunyata52
Post by sunyata52 »
Hello everyone. Could you please help me with this? :(
Although I sometimes have problems remembering things, I think that these colors were not here before.
Today I updated the software. But after the update I notice a change in the colors of the app. And I really don't like them.
The main colors I'm talking about are the color of the progress bar (both of them, the one in the transfers list and the one in in the General tab), and the color when I select a torrent from the list, or when I select Status filter, Category etc. The color is a dark grey. It may have taken it from some of my system colors? I don't know...
I am attaching a screenshot. I want the previous, standard, colors that I had for so many months. I think they were blue and maybe green? I didn't do anything to the Customize UI Theme before this happened. After this happened, I tried to change some of the colors there, from System to my choice (Palette.Base, Palette.AlternateBase, Palette.Highlight, Palette.Light and a few others) but nothing happened. I don't even know what the names of these color options mean...
Please help me use my torrent client as comfortably as I used to.
Thank you!
colors I don't like qbittorrent 5.1.0.png (141.03 KiB) Viewed 19416 times
tnt2000th
Re: After updating from v5.0.5 to v5.1.0 I don't like the new colors
Post by tnt2000th »
There are new option in : Options -> Behavior -> Color scheme (Dark/Light/System).
sunyata52
Post by sunyata52 »
tnt2000th wrote: Mon Apr 28, 2025 1:50 pm There are new option in : Options -> Behavior -> Color scheme (Dark/Light/System).
Thanks, but that's not the problem. I set my Color scheme on Light and those colors are still there.
texnick
Post by texnick »
Join the question.
Using system colors without an alternative is not a good solution.
With respect and hope for understanding.
Im experiencing the same issue.
See for more info: https://github.com/qbittorrent/qBittorrent/issues/22632
Temporarly solution;
Change your accent color in windows settings - it follows that........Qt have changed things again..
Its Qt related it seems; Newest version is using Qt 6.9.0 while previous version was using Qt 6.7.3. Im sure we will get a fix for it soon.
latheofheaven
Post by latheofheaven »
AHA! Thank you Sir! Image
sunyata52
Post by sunyata52 »
Good to know that I'm not the only one and that there is an GitHub issue open for this!
para
Post by para »
мне помогло убрать галочку в настройки -> Поведение -> список торрентов, чередовать цвета строк.
What helped me was to uncheck the box in settings -> Behavior -> torrent list, alternate line colors.
santilli
Post by santilli »
I almost fell of the chair when I opened qt and it was green! The worst part is that even if you manually set the color scheme, which is a tedious task, it will still use system colors. I only imagine what's in one's head to wake up one day feeling like changing something that nobody ever complained about, but coding is about that, I figure.
In the mean time I will use a custom theme, I picked mumble-lite.qbtheme because it looks just like the vanilla interface, only bigger.
bartonnen
Post by bartonnen »
santilli wrote: Sun May 11, 2025 7:15 pm In the mean time I will use a custom theme, I picked mumble-lite.qbtheme because it looks just like the vanilla interface, only bigger.
Thanks for the idea. I picked legacy it looks great to me, very similar to default and not enlarged like mumble.
