Add search in search!!
MiguelDJ
Post by MiguelDJ »
It would be great a second search box to "filter" the results of a search.
Example:
I search "Avira"
They appear hundreds of results.
But I want to filter one to be "Eng" os "PtBr".
I think it would be a good idea.
It is very difficult to seek an specific item in the middle of hundreds of results.
Tanks and excuse my English
Re: Add search in search!!
As far as I know there IS a way to search like that.
The easiest way is using google..as always, like: keyword site:qbforums.shiki.hu
About our forum engine phpBB, did you try Advanced search? search.php
(Also, there should be a help menu somewhere.. hidden, which tells you how to use it.)
ironcross
Post by ironcross »
I think MiguelDJ means the Search in qBittorrent... :roll:
Oh well.. :D
ironcross
Post by ironcross »
Or maybe i'm wrong... Only MiguelDJ knows :|
MiguelDJ
Post by MiguelDJ »
[quote=""ironcross""]I think MiguelDJ means the Search in qBittorrent... :roll:[/quote]
Correct. The Search in qBittorrent.
Add a second search box to filter the results of the main search in qBitTorrent.
Excuse the delay and thanks for the best Torrent program!!! :oops:
