NTFS junction point with qbittorrent's config. folders?
tekko
Post by tekko »
Has anybody tried to use NTFS junction point with qbt's config. folders, redirecting them into a removable/shared location? I am thinking to make qbt semi-portable that way, but somebody posted warnings about junction points with auto cleaner, etc. They have experienced some kind of data loss.
Would the qbt's config. folders work across different windows pc?
For more info. regarding NTFS junction point:
http://en.wikipedia.org/wiki/NTFS_junction_point
http://www.rekenwonder.com/linkmagic.htm
Dayman
Re: NTFS junction point with qbittorrent's config. folders?
Post by Dayman »
Your last link says "Junction points are transparent to programs.". So you might give it a try after backing up /User/Appdata//[Roaming|Local]/qBittorrent
