Unofficial 64-bit installer/archive 3.3.x
Re: Unofficial 64-bit installer/archive 3.0.[6-11]/3.1.0/3.2.0alpha
Thanks alot Dayman, lets test 3.2.0 with 16.12 :).
A short report about the alpha :).
I had it running for 1 day 24 hours straight and works as it should. The downloadbar looks better with qt5, overall stable alpha :D. Reverted back to 3.1.0 release just in case, both sledges and your build are working good. I've recently updated my network adapter driver through windows update and that really helped alot; smoother surfing the internet, no lag with multiplayer games and great speeds with qBittorrent. The problems I had before with 3.1.0 are gone :).
Once again thanks for your time and effort Dayman and sledge.
neatchee
Post by neatchee »
Hey Dayman, any chance of getting a 64-bit build of 3.1.1.1? Would love to get rid of that pesky update notification :3
neatchee
Re: Unofficial 64-bit installer/archive 3.0.[6-11]/3.1.[0-1]/3.2.0alpha
Post by neatchee »
You, sir, are a gentleman and a scholar.  Thank you!
EDIT: D'oh! It looks like you didn't name it 3.1.1.1, so the updater is still triggering.  Oh well.  Guess I'm turning off the update check for now heh
Re: Unofficial 64-bit installer/archive 3.0.[6-11]/3.1.[0-3]/3.2.0alpha
Thanks Dayman :).
Gúgolplex
Post by Gúgolplex »
Qt 5.2 is stable :)
Dayman
Post by Dayman »
[quote="Gugolplex"]
Qt 5.2 is stable :)
Nothing extraordinary. Good thing is I can now build QtCreator 3.0.
Gúgolplex
Post by Gúgolplex »
libtorrent-rasterbar-0.16.13 is stable :)
it's extraordinary? :D
Tomaso
Post by Tomaso »
[quote="Gugolplex"]
libtorrent v0.16.13 changelog:
* fix auto-manage issue when pausing session
* fix bug in non-sparse mode on windows, causing incorrect file errors to be generated
* fix set_name() on file_storage actually affecting save paths
* fix large file support issue on mingw
* add some error handling to set_piece_hashes()
* fix completed-on timestamp to not be clobbered on each startup
* fix deadlock caused by some UDP tracker failures
* fix potential integer overflow issue in timers on windows
* minor fix to peer_proportional mixed_mode algorithm (TCP limit could go too low)
* graceful pause fix
* i2p fixes
* fix issue when loading certain malformed .torrent files
* pass along host header with http proxy requests and possible http_connection shutdown hang
[quote="Gugolplex"]
That's always!
I hope Arvin will keep up the great work for many years to come.
Dayman
Post by Dayman »
Uploads stalled with 0.16.13, might not be good to go.
Nah, looks good, just had no active peers.
zeomal
Post by zeomal »
Nice statistics option.
Thanks.
Thanks for the changelog Tomaso, seems good again :).
