[unofficial]qBittorrent git master builds: 3.1.0RC_06102013
Latest RC build: http://qbforums.shiki.hu/index.php/topi ... ml#msg8079
ORIGINAL POST:
Here is a build of qBittorrent 3.1.0alpha12022013 from git master with:
boost 1.53
libtorrent 0.16.8
openssl: 1.0.1e
qt: 4.8.4
Built using MSVC2008.
Link1: https://mega.co.nz/#!U1V32SqR!JwsN6jAW2 ... osX1dR8tFA
Link2: http://dfiles.eu/files/wu2v6zapp
Last edited by sledgehammer_999 on Sun Oct 06, 2013 11:58 am, edited 1 time in total.
tekko
Re: [unofficial]qBittorrent git master builds: 3.1.0alpha12022013
Post by tekko »
NEW - "Run uninstaller silently just before actually doing the installation."
I think the old way of popping up the uninstaller's options is better.
Thanks for the alpha release.
Great sledge, thanks :)! By the way, what is this file qbittorrent.pdb in the same folder as qbittorrent.exe? It is 43mb at the moment.
tekko
Post by tekko »
[quote="NeMo_0"]
http://qbforums.shiki.hu/index.php?topi ... 90#msg5290
[quote="tekko"]
[quote="NeMo_0"]
Thanks tekko. Also the downloadbar is not working (pieces that you have downloaded), anyone else having this?
Dayman
Post by Dayman »
[quote="NeMo_0"]
Confirming.
tekko
Post by tekko »
[quote="NeMo_0"]
You're welcome.
Confirming that the downloaded bar is not working.
Yes I confirm this.
@Dayman, does it show up on your builds too?
@tekko, for the unistaller: I will keep the new way, unless people start bitching about it :p It's cleaner.
Dayman
Post by Dayman »
[quote="sledgehammer_999"]
Yep. Still following http://code.google.com/p/libtorrent/iss ... ail?id=406
[quote="Dayman"]
I suppose you wanted to confirm the bug and inform of a separate bug, right?
Don't worry I have subscribed to that libtorrent bug so I get all the updates. And I have to admit that you do an impressive just hunting this down and debugging. I would never been able to do that. Thank you.
Tomaso
Post by Tomaso »
[quote="libtorrent Issues"]Priority-Medium[/quote]
Makes me wonder what it takes to get the high priority label.
loki
Forum addict
Forum addict
Post by loki »
I tested this build and I didn't see the error message or crash from before.
Avelon
Post by Avelon »
Looking forward to try your new work. Thanks in advance for your efforts!
I am still using 3.1.0 alpha (the one you linked per google docs, cannot remember the build number and it's not shown in the 'About' section of qB) and my only problem is with new/unfinished torrents that I stopped. They resume randomly without my doing.
Oh and link #1 is down, by the way :)
Have a nice rest-of-the-weekend!
edit: the problem still exists. When I stop new or unfinished torrents and I quit the program and start it again, they resume automatically. But not all of it. Looks randomly or maybe only the newest ones get started again (just a clue).
Here is a build of qBittorrent 3.1.0alpha05032013 from git master with:
boost 1.53
libtorrent RC_0_16 svn branch
openssl: 1.0.1e
qt: 4.8.4
Link1: https://mega.co.nz/#!ZUkwGQCJ!R-GQrSZ7i ... dqglsyO6b4
Link2: http://dfiles.eu/files/8qmmvvzzd
This should fix many things about IO erros, corrupt files etc (libtorrent issues).
Re: [unofficial]qBittorrent git master builds: 3.1.0alpha05032013
Thanks sledge (and Dayman & others involved) for these fixed releases, for all the effort and time to make this possible :). Installing right away.
EDIT: ''Downloaded'' bar isn't working, availability bar works. Download is at 12% but shows blank instead pieces. Otherwise great speeds and stable  ;D.
