Forum: modify option doesn't work as expected.
If you want to edit a post you made by clicking the "bottom-right modify icon" the modification UI that appears on the same page is empty. Normally it should contain the text of the post you are editing. The "top-right modify icon" that takes you to a new page works as expected though.
