Hey, I would like to know if it's currently possible to change the splash screen. I don't get to see the screen for that long, but still, in the moments that qBittorrent launches, I feel like I'm awkwardly staring at a splash image that could've been prettier(even just changing the border would be enough).
Does someone happen to know if this is possible?
Is it possible to change the splash screen?
Re: Is it possible to change the splash screen?
It's not possible to change the image. You can only disable the splash screen. Tool->Options...->Behavior->Show splash screen on start up
