Can I move the Appdata files to qbittorrent's folder?
mecmecmec
Post by mecmecmec »
I don't want the settings and config files to be in the Appdata folder. Can I move them to qbittorrent's folder instead?
loki
Re: Can I move the Appdata files to qbittorrent's folder?
Post by loki »
You probably want the portable apps version, but note, it is not supported here... nor is it considered "official" and some have reported problems with this version. Just bear in mind, if you do choose this route don't expect support from here.
mecmecmec
Post by mecmecmec »
Ya I've tried the portable version and it always gives me an error message when I close the program.
