qBittorrent Needs A More Modern Look - What Do You Think?
Re: qBittorrent Needs A More Modern Look - What Do You Think?
Here a screenshot with Windows 7 32bit currently:
qBittorrent v3.1.0, latest alpha build.
Resized a bit, original resolution 1920x1080. Still loading some torrents . I like the UI, only the buttons above could use some make over.
So basically your objections are with the icons used right? Because, as far as I can tell, it otherwise uses the native style/look on the widgets.
[quote="sledgehammer_999"]
thats just it its kind of meh .. how about some Shiny things to look at like some utorrent 3 inspired UI bits like the health bars and modern icons some of the spacing/dividers in the UI looks a bit dated
QT is heavily skin-able with options such as pure css and QMT to control UI bits
[quote="Onemoar"]
(Keep in mind that I am not the person who calls the shots). I absolutely hate applications that don't use the native OS look and are using their own skin/style like nero and dvdfab. I will replace them in a heartbeat if I can find an alternative. On the other hand the icons might need a change. To be honest I don't really care and on my XP machine they dont look out of place. The problem is that you need someone to design new ones or find a suitably licensed icon theme...
Last edited by sledgehammer_999 on Fri Mar 08, 2013 11:15 pm, edited 1 time in total.
[quote="Onemoar"]
its not like it needs to be a on-by-default option
hell simply CSS support for things like the UI gradiants and backround and icons would be enough
after that its just a matter of opening photoshop or gimp and churning out some images
[quote="Onemoar"]
[quote="Onemoar"]
nice what theme is that ?
tho it does make the fugly ness of the icons standout
The theme is Pachenko: http://browse.deviantart.com/art/Pachenko-334871363
The top toolbar is hidden from the View menu in qBt, because i never use it.
[quote="res0r9lm"]
I made a few modifications to skin and left the rest as is using system icons and qt GTK+ style
Uploaded with ImageShack.us
Just looking at that GTK+ theme makes me sick..
I get associations that reminds me of how bloated that crap is!
I never cared much for bells and whistles.
Personally I prefer the grey (and dull) Windows Classic theme.
Mine looks like this
http://www.picase.net/i/56/kLh.png
Windows 8 with stock theme. UI that fits windows default and minimalistic icons would really help.
Since I was looking at UI today, I realized that it doesn't use the native widgets for all the controls. Eg it doesn't use the native progressbar for the torrent progress. I changed that in the code and here is how it looks:
I am not really sure that this is better or worse. I have mixed feelings. OS Windows XP. On Vista/7/8 it should use the native look too.
[quote="sledgehammer_999"]I changed that in the code[/quote]
Interesting. I bet it looks better with the default loading bar startin from Windows Vista to Windows 8 as they are much prettier.
Mind explaining me how to chnage that so I can test this on Windows 8?
seems "worse" to me.
[quote="Giga"]
Are you sure? You will need to recompile qbittorrent to test the changes, which can be a tedious task.
I assume that you are experienced on this and I won't give more info on the compilation process.
In src/transferlistdelegate.h search for:
and change it to:
Do almost the same in src/properties/proplistdelegate.h (adapt the code accordingly).
Wiki instruction on windows compilation: https://github.com/qbittorrent/qBittorr ... linkage%29
case TorrentModelItem::TR_PROGRESS:{
QStyleOptionProgressBarV2 newopt;
qreal progress = index.data().toDouble()*100.;
// We don't want to display 100% unless
// the torrent is really complete
if (progress > 99.94 && progress < 100.)
progress = 99.9;
newopt.rect = opt.rect;
newopt.text = QString::number(progress, 'f', 1)+"%";
newopt.progress = (int)progress;
newopt.maximum = 100;
newopt.minimum = 0;
newopt.state |= QStyle::State_Enabled;
newopt.textVisible = true;
#ifndef Q_WS_WIN
QApplication::style()->drawControl(QStyle::CE_ProgressBar, &newopt, painter);
#else
// XXX: To avoid having the progress text on the right of the bar
QPlastiqueStyle st;
st.drawControl(QStyle::CE_ProgressBar, &newopt, painter, 0);
#endif
break;
progress = 99.9;
newopt.minimum = 0;
newopt.textAlignment = Qt::AlignCenter;
break;
