Embedded tracker is not working and how to restrict access to it ?
raafat
Post by raafat »
Hi guys...i have enabled an embedded tracker but when opening that torrent file i'm recieving a message telling me : Not working,Torrent unauthorized
that my first problem.
my second problem is:
How to restrict access to my tracker ?
meaning i want only myself to can use that tracker .
thank you .
loki
Re: Embedded tracker is not working and how to restrict access to it ?
Post by loki »
I don't get it, I thought the reason to setup or use the embedded tracker was so that OTHERS could use it...?
raafat
Post by raafat »
Yes OTHERS will use it but not everybody i want somebody .
Any an idea about that ?
I haven't tested the tracker capabilities of qbittorrent but I am pretty sure that it can't do what you want. It is a simple tracker.
If you want more control of your tracker/seeder you have to find a specialized program for that.
You could use a firewall on the host machine and only let one IP connect to the tracker running.
(Not sure which firewall software could do this. Comodo maybe.)
But this is not what the embedded tracker is meant for. It's a simple opentracker-like tracker, nothing serious.
It does what it is supposed to do, and that's it.
raafat
Post by raafat »
As you said it does't do what i want it's just a simple tracker...thank you guys *__________*
