[unofficial]qBittorrent git master builds: 3.2.0alpha_20150308_19b9a84
Re: [unofficial]qBittorrent git master builds: 3.2.0alpha_20150308_19b9a84
[quote="Douman"]
@sledg,
I found interesting thing. It seems latest builds make double-initialization:
It is intended behavior when you use "any network interface" in the settings. It tells the OS to use the default route and on Windows 7+ (and maybe vista) that also means the ipv6 default route too...
See bugs #2611 and #2165
junpet
Re: [unofficial]qBittorrent git master builds: 3.2.0alpha_20150201_6209d88
Post by junpet »
[quote="sledgehammer_999"]
Here is a build of qBittorrent 3.2.0alpha sha1 19b9a84 from git master with:
boost 1.55
libtorrent 1.0.3svn+r10821
qt: 4.8.6
Built using msvc2013
Git changelog from last alpha: https://github.com/qbittorrent/qBittorr ... e3b696aa95
Link 1: http://www.fosshub.com/qBittorrent.html
Link 2: http://builds.shiki.hu/qbittorrent_3.2. ... _setup.exe
I don't know where I should report this bug (here or github), but I give a try here.
After I restart qBittorrent on the RSS tab the layout settings change to default. Here's 2 pic what I mean:
I set the layout which comfortable to me:
http://i.imgur.com/TNm1pdp.png
Then after restart:
http://i.imgur.com/KFbSRZq.png
I use the quoted version, Windows 7 SP1 x86.
tekko
Post by tekko »
Just an update... I was having system freezes with libtorrent 1.0.x builds. I got rid of my raid0 and it seems to be running fine now.
xp x86
Used 3.2.0 with raid0 (intel RST), no issues at all.
(there is some issue with one of those drives I guess. check smart data.)
tekko
Post by tekko »
I removed those drives already...
They could be bad drives, but it didn't happen with the temp alpha built against libtorrent 0.16.x (3.2.0alpha_20150203_6209d88_libtorrent0.16)
:o
