Problems on Mac OS with > 2.55?
bluecar
Post by bluecar »
Anybody else having issues with the latest versions on Snow Leopard? I haven't pinned down the exact release where the problem started but on current versions I'm having problems connecting to peers and downloading torrents. If I drop back to 2.5.5 or earlier, using the same preference settings, things take off. I've looked at all qbittorrent settings as well as router settings and can't find anything to explain this. Console log certainly has lots of qbittorrent msgs but nothing that would seem to explain this issue.
bluecar
christophe.dumez
Re: Problems on Mac OS with > 2.5.5?
Post by christophe.dumez »
I suggest you contact the Mac maintainers about this:
Name: Stefanos Antaris (aka "Santaris")
Mail: santaris (at) csd (dot) auth (dot) gr
Mail: infinity89 (at) fastwebmail (dot) it
bluecar
Re: Problems on Mac OS with > 2.55?
Post by bluecar »
I forwarded this issue to their attention. Will post back with any resolution.
Thanks!
bluecar
bluecar
Post by bluecar »
Mirco and Stephanos are aware of this problem and have a fix in development. They will incorporate the fix in their next release.
bluecar
