Hello everyone!
I wanted to know if there was a way to compact a file automatically downloaded via QBittorent
I normally use this command: rar a-m0-v400M-R "file" "folder name"
you can put in the automatic procedure?
Rar file downloaded after Download
Re: Rar file downloaded after Download
Why not use 7zip by the way? It's compression is much better and it's free. Just my two cents.
for convenience .. however, there is a way to shrink automatically?
Without Chris's reply, we don't know for sure, but at this moment there is no such option (as far as I know) in qBittorrent at the moment.
This would need a "run command after download" or something like that box.
However, if you watch the output of qBittorrent, you may be able to compress them using a script. It's not easy, not clickety-click for sure.
(So when a download finishes, there is something in the output. WHEN that comes, the script would compress the given folder/file.)
Anyway. Open a ticket on the bugtracker for this, as a feature request.
