ver 3.2.0a leaving !qb files in "Move completed to" location
ciaobaby
Post by ciaobaby »
Issue #1461 raised at GitHub c/w screen shot.
Re: ver 3.2.0a leaving !qb files in "Move completed to" location
Can you answer the questions on the issue? Also your link is broken.
ciaobaby
Post by ciaobaby »
Ok, I will I haven't answered because I have not had any notification of replies and wasn't aware of any questions.
There is a stray " in the URL if somebody wants to edit  the link.
[quote="ciaobaby"]
I can edit your post, but you should be able to edit too. Are you sure you can't? Look for the icon at the bottom right corner of the post.
ciaobaby
Post by ciaobaby »
So I can, I take that SMF's edit time limit is turned off then.
