Thank you for your great software.
Ubuntu 64 bit
I downloaded the source and compiled without problem.
In 3.1.8 Options -> Downloads -> Select "Pre - allocate disk space for all files"
You download 1 file ( it doesn't matter the size) 90% ... 95% ... just before the 100% ... puff crash.
GUI or shell - Bash
Catching SIGSEGV, please report a bug at http://bug.qbittorrent.org
and provide the following backtrace:
qBittorrent version: v3.1.8
stack trace:
/lib/x86_64-linux-gnu/libc.so.6 : ()+0x36460 [0x7f4035165460]
/usr/local/lib/libtorrent-rasterbar.so.7 : libtorrent::default_storage::readwritev(iovec const*, int, int, int, libtorrent::default_storage::fileop const&)+0x810 [0x7f4037c5f7b0]
/usr/local/lib/libtorrent-rasterbar.so.7 : libtorrent::default_storage::writev(iovec const*, int, int, int, int)+0x5d [0x7f4037c5faed]
/usr/local/lib/libtorrent-rasterbar.so.7 : libtorrent::piece_manager::write_impl(iovec*, int, int, int)+0x9d [0x7f4037c65c4d]
/usr/local/lib/libtorrent-rasterbar.so.7 : libtorrent::disk_io_thread::thread_fun()+0x3286 [0x7f4037b31c06]
/usr/local/lib/libtorrent-rasterbar.so.7 : boost_asio_detail_posix_thread_function()+0xe [0x7f4037b010de]
/lib/x86_64-linux-gnu/libpthread.so.0 : ()+0x7efc [0x7f40375f8efc]
/lib/x86_64-linux-gnu/libc.so.6 : clone()+0x6d [0x7f4035213f8d]
Segmentation fault
If you de-select ... everything work ok.
Thank you
Neuron
3.1.8 - "Pre - allocate disk space ..." crash
Re: 3.1.8 - "Pre - allocate disk space ..." crash
Has been reported, and fixed in latest alpha and planned to be included in 3.1.9, about 2 weeks ago. No release for 3.1.9 yet though.
[quote="loki"]
But I searched the reason and where it crash and I can't find the details.
Another bug (Ubuntu 64 bit):
"Successfully parsed the provided IP filter: 273695 rules were applied." ok
then
Execution Log -> Blocked IPs
If I check the IP's up and down, sometimes the CPU get 100 % and I need restart.
Best regards,
Neuron
then
Best regards,
Neuron
Just so you know. For the fix you don't need new qbt code but new libtorrent code. libtorrent 0.16.15 contains the fix.
[quote="sledgehammer_999"]
Thank you Sir,
But I don't need to compile QBit ?
Only Lib???
Neuron
Thank you Sir,
Only Lib???
Neuron
only libtorrent. But qbt will still show the previous version in help->about->libraries.
Thank you very much for the support !!!!!!
