After adding this ppa via 'sudo add-apt-repository ppa:hydr0g3n/qbittorrent-stable'
I get the following in the synaptic package manager:
Failed to fetch http://ppa.launchpad.net/hydr0g3n/qbitt ... es.gz 404 Not Found
Some index files failed to download, they have been ignored, or old ones used instead.
Am I just out of luck, no longer supported?
M.
Ubuntu 10.04 lucid i686
Re: Ubuntu 10.04 lucid i686
The oldest ppa is Ubuntu version 12.04 Precise "This PPA currently publishes packages for Saucy, Raring, Quantal, and Precise."
https://launchpad.net/~hydr0g3n/+archiv ... /+packages
So if you wish to continue using the ppa's you will have to update your links
To do this in Synaptic:
Synaptic>Settings>Repositories>Other Software
Edit to
http://ppa.launchpad.net/hydr0g3n/qbitt ... ble/ubuntu precise main
Close, click reload, enter qbittorrent in the search filter, and the installed and latest available version will be listed.
or
Manually edit /etc/apt/sources.list
Edit to
or
Ah ok it's backwards compatible. Cool.
I shall give it a go when I get home. Much prefer to use this software, however there is a small 'feature' in 2.2.5 that is driving me nuts.
Cheers.
M.
Cheers.
M.
