[Solved] How to reset user interface password
HI ! i'm blocked out of qbit, I can only force terminate process but when i restart, it start on try icon and cannot see UI. I've tried to uninstall and reinstall package but still not work ! it say: "please insert password for UI block" What can I do?
Re: how to rst userinterface pwd
If you remove qbittorrent settings file then it should work.
WARNING: You will lose every setting you have customized about qbittorrent!
Delete these folders:
1. C:Documents and Settings<username>Application DataqBittorrent
2. C:Documents and Settings<username>Local SettingsApplication DataqBittorrent
