Are retransmissions and failed connections normal in p2p?
morfikov
Post by morfikov »
This is a log from netstat after 3h of running qbittorrent on my pc:
$ netstat -s
Ip:
    999320 total packets received
    94636 forwarded
    0 incoming packets discarded
    884213 incoming packets delivered
    1184677 requests sent out
    1898 outgoing packets dropped
    1 dropped because of missing route
    60 fragments received ok
    120 fragments created
Icmp:
    25011 ICMP messages received
    5687 input ICMP message failed.
    ICMP input histogram:
        destination unreachable: 23898
        timeout in transit: 1105
        redirects: 3
        echo replies: 5
    644 ICMP messages sent
    0 ICMP messages failed
    ICMP output histogram:
        destination unreachable: 639
        echo request: 5
IcmpMsg:
        InType0: 5
        InType3: 23898
        InType5: 3
        InType11: 1105
        OutType3: 639
        OutType8: 5
Tcp:
    97509 active connections openings
    1876 passive connection openings
    60911 failed connection attempts
    2291 connection resets received
    6 connections established
    489070 segments received
    591406 segments send out
    62036 segments retransmited
    699 bad segments received.
    3557 resets sent
Udp:
    369824 packets received
    213 packets to unknown port received.
    0 packet receive errors
    512524 packets sent
UdpLite:
TcpExt:
    3 ICMP packets dropped because they were out-of-window
    6790 TCP sockets finished time wait in fast timer
    4487 delayed acks sent
    58 delayed acks further delayed because of locked socket
    Quick ack mode was activated 1005 times
    463 packets directly queued to recvmsg prequeue.
    3070 bytes directly in process context from backlog
    30241 bytes directly received in process context from prequeue
    152172 packet headers predicted
    83 packets header predicted and directly queued to user
    119279 acknowledgments not containing data payload received
    76845 predicted acknowledgments
    1 times recovered from packet loss due to fast retransmit
    1604 times recovered from packet loss by selective acknowledgements
    Detected reordering 1 times using FACK
    Detected reordering 6 times using SACK
    234 congestion windows recovered without slow start by DSACK
    809 congestion windows recovered without slow start after partial ack
    TCPLostRetransmit: 765
    84 timeouts after SACK recovery
    95 timeouts in loss state
    6974 fast retransmits
    265 forward retransmits
    358 retransmits in slow start
    26137 other TCP timeouts
    TCPLossProbes: 4764
    TCPLossProbeRecovery: 1727
    144 SACK retransmits failed
    1070 DSACKs sent for old packets
    4 DSACKs sent for out of order packets
    2911 DSACKs received
    1 DSACKs for out of order packets received
    201 connections reset due to unexpected data
    865 connections reset due to early user close
    376 connections aborted due to timeout
    TCPDSACKIgnoredOld: 4
    TCPDSACKIgnoredNoUndo: 1564
    TCPSpuriousRTOs: 129
    TCPSackShifted: 37
    TCPSackMerged: 9428
    TCPSackShiftFallback: 26231
    TCPRetransFail: 2262
    TCPRcvCoalesce: 33276
    TCPOFOQueue: 6611
    TCPOFOMerge: 4
    TCPChallengeACK: 803
    TCPSYNChallenge: 750
    TCPSpuriousRtxHostQueues: 339
IpExt:
    InMcastPkts: 13030
    OutMcastPkts: 18252
    InBcastPkts: 5252
    OutBcastPkts: 462
    InOctets: 269470040
    OutOctets: 775136946
    InMcastOctets: 2145695
    OutMcastOctets: 3004421
    InBcastOctets: 1561083
    OutBcastOctets: 76230
    InNoECTPkts: 998626
    InECT1Pkts: 70
    InECT0Pkts: 113
    InCEPkts: 575
As you can see the amount of failed connections is a little bit stunning -- it's almost 2/3 of the total number of connections. The second thing are retransmissions, and again the number of segments that was retransmitted is quite high.
When I turn qbittorrent off, retransmissions do exist, but the value is about 0,01%, and there's no failed connection at all or maybe just single ones.
The question is: is it normal to get so high numbers for retransmissions and failed connection when it comes to torrents and other form of p2p? Maybe is there something I can do about it? Is there a chance that NAT can break those connections?
ciaobaby
Re: Are retransmissions and failed connections normal in p2p?
Post by ciaobaby »
Yes and yes.
Peers drop connections all the time, if they have broadcast a piece request and a peer other than your client fufills that request, connections that were made as 'optimistic' can be dropped.
