lgallard
Re: qBittorrent Client for Android
Post by lgallard »
@sledgehammer_999 thanks for the tip...changed to Transfixed https://www.transifex.com/projects/p/qbittorrent-client
I hope people get involved!
Btw, both Translation platforms have its appealing, but I will stick to qBittorrent translation platform!
Best regards!
sloxl8
Post by sloxl8 »
[quote="lgallard"]
@loxl8 What qBittorrent (WebUI) version are you using? For Version 2.x.x, if the .torrent file is too big, qbt server ignores it.
Qbittorrent server (on Windows desktop) is of  version 3.1.10, whereas qbittorrent client on Android is of version 2.5.1.
lgallard
Post by lgallard »
It should work...if you can, try to see the qBittorent (Web UI) logs when adding the torrent to check the client is sending the command. Best regards!r
sloxl8
Post by sloxl8 »
Where can I find logs for Web UI?
I should mention that I can successfully add torrent using Web browser on Android and qbittorrent server address, however adding torrent using qbittorrent client app on Android isn't successful. I would however like to use qbittorrent client app to add, monitor and delete torrents on server.
lgallard
Post by lgallard »
@slox8 I'm guessing, but I think in Windows all qBittorrent related data is store in C:\Users\[User]\AppData\Roaming\qBittorrent.
lgallard
Post by lgallard »
@slox8 in deed there was problem with magnet and torrent links. The fix will be available in the next release. Thanks for reporting the issue.
Best regards!
lgallard
Post by lgallard »
Release 2.6.0
  • Fixed add by torrent links and magnets
  • Added Portuguese translation (thanks vitorsena - Vitor Sena Melgaço)
  • Finished French translation
qBittorrent Client (Free)
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v2.6.0
qBittorrent Client Pro
Available on Google Play https://play.google.com/store/apps/deta ... tclientpro and GitHub https://github.com/lgallard/qBittorrent-Client
sloxl8
Post by sloxl8 »
Adding by tapping torrent file still not working. It says "Torrent file sent!"  and then "Refreshing"  and nothing else happens. Torrent is still not added to qBittorrent and is not downloading.
lgallard
Post by lgallard »
@slox8 it works with downloaded torrents files,with torrent links and torrent magnets...can you send me the torrent file? Did you see your qb server's logs?
Best regards!
sloxl8
Post by sloxl8 »
It doesn't matter what torrent file I try to sent to qBittorrent, there is no error message in the execution log in qbittorrent server. It says it is listening on WebUI port and qbittorrent client can read all the torrents on the server, but it cannot write to it. What else may I try?
Do I need to add any special rule to Windows firewall and if so what this should look like?
lgallard
Post by lgallard »
I tried version qBittorrent Client version 2.6.0 on three different devices and it worked. Can you send your logs?
You shouldn't have anything else on Windows firewall but your Web UI port defined (default 8080).
sloxl8
Post by sloxl8 »
I'm still trying to figure out why adding torrent files to the server is not working. Below you will find snapshot of the qBittorrent server log.
It is interesting I can delete torrent from the client, but I cannot add any new one.
I would appreciate any advice that would help me set-up and use the client to manage torrents.
lgallard
Post by lgallard »
But logs remains the same after sending the torrent???
sloxl8
Post by sloxl8 »
Yes,  there is no change in the log, unless I delete torrent remotely or manage torrents locally on the server.
lgallard
Post by lgallard »
Release 2.7.0
  • Added Italian translation
  • Changed layout for better distirbution in phone and tablets
  • Added handle of empty item list due to fragment stack resume
  • Fix "qBitttorent Server" typo
