Re: qBittorrent Client for Android
The server side of course is coded with C++. The client side is regular html/css/javascript etc.
I think we need someone that would be familiar with both sides. Because news features need to be supported by the server fist before the WebUI can utilize them.
And I don't know if you want to mess with C++.
I haven't worked with C++ since 2011, but I can give it a try in my spare time.
But I would like to finish other features in qBittorrent Client for Android first, for instance the upload & download rate limits (WIP ).
[quote="lgallard"]
I know that feeling, though for me it was 2003 when I last did any "serious" C++ work, it's like being a "newbie" all over again
Release version 1.7
Changelog
Changelog
- Added some qBittorrent server options edition
- Fix refresh issues with bad connections (Thanks Renato Ramos)
Thanks again mate. Its nice to see the improvments.
Release version 1.8
Changelog
Changelog
- Added download and upload rate limit per torrent
- Fixed some timeout condition issues
- Torrent details menu item rearragned
Hi everyone,
I launched a new paid version called qBittorrent Client Pro, availbale on Google Play https://play.google.com/store/apps/deta ... tclientpro
This version includes a nicer UI, the latest features and fixes of qBittorrent Client for Android and some features only available on qBittorrent Client Pro.
qBittorrent Client (free) vs. qBittorrent Client Pro
Both versions have the same functions for handling qBittorrent servers, but qBittorrent Client Pro is the paid version which includes a nicer UI, and the latest features and fixes of qBittorrent Client for Android.
By the way, both versions are published at github, but the apk file for the Pro version will be only available on Google Play.
I hope you enjoy both versions...
Best regards!
Best regards!
Yes.
As long as he has the source open and available. Also he doesn't use AFAIK any source code from qbt, only the public api.
As Nemo said, I only use the API and all sources are available at GitHub.
qBittorrent Client: https://github.com/lgallard/qBittorrent-Client
You can download the whole project for qBittorrent Client Pro, compile it on Eclipse Android Studio, generate the apk and install it on your Android device...or if you want you can buy the paid version to have the latest apk version delivered by Google Play.
[quote="lgallard"]
As Nemo said, I only use the API and all sources are available at GitHub.[/quote]
Nitpick: That quote is from me :p
For anyone wondering the GPL doesn't fordid charging for binaries.
In this case, the qbt's API is used and none of its code. And as far as I know, you cannot copyright an API.
Sorry for the wrong quoting...
That's right GPL licensing only apply for source code. And you can find example even in Linux (Red Hat and SuSE) and other Android apps (for instance Owncloud).
[quote="sledgehammer_999"]
[quote="lgallard"]
Haha , forgot to put your name I see. So by this; I quoted sledge .
Thanks lgallard.
[quote="lgallard"]
Thanks lgallard.
Release version 1.9.1 - qBittorrent Client (Free)
Changelog
Changelog
- Added Upload and download rate limit for tablets
- Fixed issue related to empty port number field
- Fixed About text
- Added the refresh option when launching the app
- Trapped odd condition when changing account's server and setting upload and download limit rates
- Added "(KiB/s)" units in upload and download dialogs
- Changed typo "qBitttorrent" application name
- Added the retrieval of qBittorrent's options after changing the account's settings
- Added Ads
