Re: qBittorrent Client for Android
[quote="sloxl8"]Yes, there is no change in the log, unless I delete torrent remotely or manage torrents locally on the server.[/quote]
sloxl8, tested with qBittorrent 3.1.11 on Windows 7, and qBittorrent Client Pro 2.7.0. Both torrents were sent using the phone, one with a downloaded torrent file, and the other using a magnet link.
Best regards!
Best regards!
Sorry I'm just not able to figure out why it doesn't work. So, I'm Smith ng to Transdroid which works flawleslly.
I hope some future version if your app will work as designed.
@sloxl8 if you have your server set to other language different than English, it might not work.
By the way, Transdroid never worked for me, and it doesn't support all the qb features, but if it works for you, is okay.
Best regards!
Best regards!
Release 2.7.0
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v2.7.0
Enjoy
- Added Italian translation
- Changed layout for better distirbution in phone and tablets
- Added handle of empty item list due to fragment stack resume
- Fix "qBitttorent Server" typo
Enjoy
Release 2.7.1
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v2.7.1
Available on Google Play https://play.google.com/store/apps/deta ... tclientpro and GitHub https://github.com/lgallard/qBittorrent-Client
- Fix crashes due to the handling of fragments handling
- Fix crashes due to showing dialogs in background while closing the app
Release 2.8.0
- Added Polish translation
- Added detection and notification of "Unauthorized access", "IP address banned condition" and "Connection timeouts"
- Fixed download size calculation
Going good mate, thanks.
Release 2.9.0
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v2.9.0
Screenshoots
Phone's view
Available on Google Play https://play.google.com/store/apps/deta ... tclientpro and GitHub https://github.com/lgallard/qBittorrent-Client/tree/pro
Screenshots
I hope people like the new look and feel...enjoy
- Added new set of icons for renewed look and feel
- Deleted log messages no longer used to improve performance
Screenshoots
Phone's view
Screenshots
Any chance you could make the homescreen icon bigger? It's much smaller than the other icons on my homescreen. Just a minor request so please don't make it a priority but it would be nice if this app were consistent with the other app icons on my phone. Thanks for your work!
Hi Calidude,
Thanks for your comments. Yes it can be changed, it's a minor fix therefore it will be in the next release.
Best regards!
Best regards!
[quote="lgallard"]Thanks for your comments. Yes it can be changed, it's a minor fix therefore it will be in the next release.[/quote]
Awesome, thanks. I hope you don't mind another request, but any chance of implementing a dark theme option?
@Calidude
I have't thought about a dark theme. I'm going to check how easy it is and include it in future releases.
Best regards!
Best regards!
Release 3.0.1 - qBittorrent Client Pro
Enjoy
- Added Properties, Files and Trackers in torrent's details
- Added Swedish translation
- Added all icon resolutions (mdpi, hdpi, xhdpi, xxhdpi)
Enjoy
Thanks mate.
