Re: qBittorrent Client for Android
Release 3.0.1 (Free) / Release 3.0.2 (Pro)
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v3.0.1
qBittorrent Client Pro
Available on Google Play https://play.google.com/store/apps/deta ... tclientpro and GitHub https://github.com/lgallard/qBittorrent-Client
As usual, enjoy
- Added Properties, Files and Trackers in torrent's details
- Added Swedish translation
- Added all icon resolutions (mdpi, hdpi, xhdpi, xxhdpi)
- Fixed crash when opening the app (missing strings issue)
As usual, enjoy
Release 3.2.0
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v3.2.0
Enjoy
- Added sort by Name, ETA, Priority, Progress, ratio, upload and download speed (ETA by default)
- Added reverse order for sorting
- Fixed refresh period list check
- Fixed some typos
Enjoy
Release 3.3.1
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v3.3.1
Available on Google Play https://play.google.com/store/apps/deta ... tclientpro and GitHub https://github.com/lgallard/qBittorrent-Client/tree
Enjoy
- Added multi choice of torrent in list. Now you can start, pause, and delete several torrents at the same time from the torrent list.
- Remove unnecessary "Refreshing" message. The progress bar indicator it's enough.
- Fixed not refresh after delete torrents and torrents with data (multi choice)
Enjoy
[quote="lgallard"]
@Calidude
I have't thought about a dark theme. I'm going to check how easy it is and include it in future releases.
Best regards!
Enjoy
@Calidude
Feature included as an issue/milestone at GitHub for future releases https://github.com/lgallard/qBittorrent ... /issues/10
Best regards,
@Calidude
Best regards!
Enjoy
@Calidude
Best regards,
from my experience I can say that the best player for not transcoded stream HD channels is a standard Android player
Hi KennethTien,
Thanks for sharing that information.
Best regards!
Best regards!
Release 3.4.0 (Pro version)
Enjoy
- Added dark theme
- Added refreshing options: 5, 10, 15, and 20 seconds
- Added top and bottom priority options
- Added increase and decrease priority in multi choice mode
- Added set upload and download limits in multi choice mode
- Fixed avoid refreshing when multi choice mode is active
Enjoy
Release 3.4.2 (Pro version)
qBittorrent Client (Free)
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v3.4.2
Enjoy it
- Added dark theme
- Fixed wrong message when setting upload rate limit
- Fixed typo in dark theme
- Fixed minor issues
Enjoy it
Release 3.5.0
- Added support for qBittorrent version 3.2.x
- Added torrent recheck
Thanks for your efforts lgallard.
You are welcome my friend...I'm working in more features!
- qBittorrent Client Pro
Release 3.5.1- Changed queued icon for better display in dark theme
- Fixed global_upload retrieving
- Fixed some typos
Release 3.5.1- Added support for qBittorrent version 3.2.x
Available on Google Play https://play.google.com/store/apps/deta ... rentclient and GitHub https://github.com/lgallard/qBittorrent ... tag/v3.5.1
Happy sharing
Hello people!
I am using a linux version and I am very pleased with the app, but I can not configure the server account in this version for Android. I have a home network with router and follow some tutorials according to my local server settings, yet it finds no connection. There is no option to enable the WEB UI in the app settings. Please my friends, I would like some help.
Hi fhmcasado,
In order to enable the Web UI follow the instructions explained here https://github.com/lgallard/qBittorrent ... ent-Web-UI. Then you should be able to connect to your qBittorrent server using the Android app or using a web browser.
Please, keeps me informed about your results!
Best regards!
Best regards!
