Hi there,
qBittorrent Controller on Android. Communications with my server is fine. But it is not reading RSS. I tried atom files, as well as regular http links, and nothing:
http://feed.rutracker.cc/atom/f/9.atom
https://rutracker.org/forum/viewforum.php?f=189
qBittorrent on PC reading atom files with no problems.
What am I doing wrong?
Thanks.
- Newbie
Re: qBittorrent Controller for Android
Hi Galushkino,
It happens when the RSS feed doesn't follow the standard
For further issues you can addressed them here https://github.com/lgallard/qBittorrent ... ler/issues
Regards,
Regards,
Release 4.5.8
Available on:
Google Play: qBittorrent Controller Pro / qBittorrent Controller Free
GitHub: qBittorrent Controller Free
- Fixed Host header according to RFC 2616
Available on:
hello
I am having a problem connecting with the web UI of qbittorrent ver 3.3.16 I have followed the instuctions you gave and I can access the web UI using the address 192.168.0.195:8080 in a browser window on the same pc as qbittorrent is installed on and also from another pc on my home network. But I cannot connect using my android phone with the same address settings. do you have any idea why this would be happening. I am using the latest version of the controller ver 4.5.8. any help would be appreciated.
thanks
thanks
I would definitely recommend to use qbittorrent remote by fengmlo over this one.
It has far more features and has regular updates.
