seltzermx
Re: qBittorrent Controller for Android
Post by seltzermx »
[quote="lgallard"]
Release 4.4.3
  • Fixed Opening of endless chrome tabs issue (this was reported by seltzermx)
  • Fixed how the sent torrent is encoded
Available on:
Google Play: qBittorrent Controller Pro  / qBittorrent Controller Free
GitHub: qBittorrent Controller Free
You da man!!
Tried it and it worked perfectly. Got the Pro version. Just waiting for the 4.4.3 update to reach my phone.
Thank you!!
lgallard
Post by lgallard »
Thanks for supporting the app by buying the app  :D
Release 4.4.4
  • Fixed sending of magnet links issue
Available on:
lgallard
Post by lgallard »
Release 4.4.5
  • Fixed issue with qBittorrent 3.1.10
  • Force to request a new token every time the app is started
Available on:
lgallard
Post by lgallard »
Release 4.4.6
  • Fixed magnet link not working issue
Available on:
MJ.nfl
Post by MJ.nfl »
When I'm on my home wi-fi I can successfully manipulate torrents with qbittorrent controller.
Problem occurs when I'm on other wi-fi's than it simply doesn't work.
What am I doing wrong?
Thanks.
Nothing, if you have your local IP added in the controller, then it won't work.
Like, when you move to another WIFI, even inside your house, that's a different network.
BUT, you can forward out your port, and reach it from anywhere.
http://www.howtogeek.com/66214/how-to-f ... ur-router/
https://www.noip.com/support/knowledgeb ... no-ip-com/
lgallard
Post by lgallard »
Release 4.4.8
  • Added a dialog for for changing save path and label for qBittorrent 3.2.x.
  • Added enable/disable of save path and label dialog box.
Available on:
lgallard
Post by lgallard »
Release 4.5.0
  • Fixed issue when sending torrents from downloads (thanks magicoolje)
  • Added French translation (thanks Arnaud Guenee)
Available on:
lgallard
Post by lgallard »
Release 4.5.1
  • Fixed Torrent details issue on Android 7.x
  • Updated French, Italian, Hungarian and Japanese translations
Available on:
Thanks lgallard.
lgallard
Post by lgallard »
You are welcome my friend!
lgallard
Post by lgallard »
Release 4.5.2
  • Fixed save path and label (category) behavior
  • Improved handle of downloaded torrent files
  • Added handling of save path and labels from Add torrent link menu option
  • Added enabling of save path and label (category) preference for API7+ (qBittorrent 3.3.1+)
  • Added download url command for API7+ (qBittorrent 3.3.1+)
  • Removed old way to get files from download list
  • Removed debug messages
Available on:
lgallard
Post by lgallard »
Release 4.5.3
  • Added  qBittorrent 3.3.13 compatibility (fixed CSRF in API requests)
  • Added support for moving the app to SD cards
  • Updated larger aspect ratio for new Android flagship devices
  • Added delay  time before sending file to qBittorrent
Available on:
lgallard
Post by lgallard »
Release 4.5.4
  • Added Host and Referer for subfolder case
  • Changed upload and download order in torrent info to match with the upper bar info.
Available on:
lgallard
Post by lgallard »
Release 4.5.5
  • Set Host header to hostname for subfolder case
Available on:
