Hi Fabryprog,
Just discussed about your app accidentally here http://qbforums.shiki.hu/index.php?topic=2655
Congrats! I probably won't use it, I don't need it right now, but others...
You will put ads on it?
How you will capitalize?
[quote="hyperion1is"]
Hi Fabryprog,
It isn't a same app!!!
This app was written for personal use. Then they suggested I publish it!
You're wrong .. the app does not have and will not have adv!
I didn't meant anything wrong by it.
"It isn't a same app!!!" ?
"This app was written for personal use. Then they suggested I publish it! " Who?
"You're wrong .. the app does not have and will not have adv!"
I never said it has. I only asked, since I know that is a fee of 25$ to publish it on Google Play.
Anyway, good job, as I said before. Anyone who is using your app should appreciate your work.
