Force Start option like in µTorrent
csenger41
Post by csenger41 »
I would like to see a "Force Start" option in qBittorrent too. Sometimes that feature came handy and I am missing it so badly.
Trond
Re: Force Start option like in µTorrent
Post by Trond »
1
s4nder
Post by s4nder »
Disable the queue and all torrents are automatically force started when you launch the program.
Tofi
Post by Tofi »
[quote="s4nder"]
[/quote] "Force start" not working in this way. "Force start" its is override of max allowed UL/DL torrents i.e. max is 3 torrents started and you want to add to this one selected torrent with priority #6, then you forcing start and now active torrents are #1,#2.#3,#6.
Sign me in for that option too.
res0r9lm
Post by res0r9lm »
[quote="Tofi"]
[quote="s4nder"]
Force start circumvents queue and scheduler so if you disable queue all torrent would be same as force started or you can set queue to the proper values
tobindax
Post by tobindax »
+1
And completely different from manually disabling a queue system. This is strictly for "once in a while for an exception" only. It defies the purpose to force users to not have it because "theoretically they can do it with a queue". Well duh, that's the feature, to avoid changing the settings when they only need it for one torrent only.
