Theme
Theme
If anyone knows a good editable phpBB theme, please post a name / link. Checked the original site but there you can't really find a good one.
Edit: Enabled a new theme called: ProFormell. Hope you will like it. (If I can customize it to be .."qBittorrent like" and make it a new good theme, I'll make it default later).
BlaXpirit
Re: Theme
Post by BlaXpirit »
This theme is OK.
In my opinion, simply changing the logo will do.
Re: Theme
Yeah yeah working on that right now. :) Christophe just sent the images.
Glad to see people already found the forums. I'll create an introduction section.
Quite strange. It took a while I found the file for images. The config is in the "imagesetimageset.cfg". Modified it to the corresponding size but it ignores it and gets a "width="139"" somewhere. Investigating this problem, so please bear with the ugly/broken header until then. :)
UPDATE: Fixed it. It was "hard-coded" in the settings/SQL. Don't know who came up with this crazy idea, but damn... wasn't really straight-forward.
DasFox
Re: Theme
Post by DasFox »
The default theme is ok, just use it! :)
