qBittorent portable - Python portable
rbon
Post by rbon »
I have download from PortableApps.com the program "qBittorrent Portable" (http://portableapps.com/apps/internet/q ... t_portable).
When I launch a Search, the program tell me: "Python 2x is required to use the search engine but it seem to be installed. Do you want to install it now?".
So I ask You: It's possible to use Python Portable? (web site http://portablepython.com/).
I think that You can add a new item in "Tools -> Options" with the path of Python Portable.
btw
I don't know what version of Python Portable that I can use and where I can put Python executables.
Thanks
Re: qBittorent Portable - Python Portable
You should create a topic about this at the PortableApps forum.
Even if Chris adds an option, the PortableApps version will be totally unrelated.
It's their "problem" (job?) to make it possible to integrate it.
(I'm thinking about an extra download like the Pidgin-OTR Portable, or the LibreOffice language packs Portable.)
rbon
Post by rbon »
[quote=""shiki""]You should create a topic about this at the PortableApps forum.
(I'm thinking about an extra download like the Pidgin-OTR Portable, or the LibreOffice language packs Portable.)[/quote]
OK
thank for Your reply.
btw
I have look and the main program is identically in both version (original and portable).
