When I view my torrents via remote http from an Android Tablet I can only see the tabs Trackers, Peers, etc but I can't see or open the main windows where torrents are.
Is that a bug, a feature or there is a way to have them displayed?
Dejan
Remote Control via http on a Tablet
Re: Remote Control via http on a Tablet
Try the latest alpha version: http://qbforums.shiki.hu/index.php/topi ... l#msg15534
It has a refactored WebUI. Caution: Reset your password because the old one will not work. (You can input the same one and hit save again)
If you are using Android, you can give a try to my application http://qbforums.shiki.hu/index.php/topic,2655.0.html
Best regards!
Best regards!
