WebUI credentials
marcolem
WebUI credentials
Post by marcolem »
Hi, I just installed qbitorrent-nox and setup the WebUI. I changed the default port and the credentials and an alertbox with 0 showed up... the port was changed sucessfully but neither default credentials nor new credentials are working. Is there any way to reset those settings?
marcolem
Re: [ubuntu] WebUI credentials
Post by marcolem »
I read another post and found my answer about the settings file. My new username was there and password is a byteArray so I can't say what was saved there.
christophe.dumez
Post by christophe.dumez »
If you delete the two corresponding lines in the settings file and then restart qBittorrent, this will reset your username password.
christophe.dumez
I can reproduce the alert message here. This is simply a debug alert I forgot to remove, this is now fixed in SVN. However, this alert does not affect the settings saving.
Here, I can successfully change the username/password from the Web UI.
jazzmo
Re: WebUI credentials
Post by jazzmo »
I just compiled and installed the latest git clone (qbittorrent-nox) on squeeze, created a debian package for it. I have a problem with the WebUI credentials though: after downloading for a while I was not able to log on with my password (changed it from the default adminadmin). After I deleted it from the config file and reset it it was working again, but after a while i was not able to log on again. Could you please check this? If it makes sense I could compile the latest git clone for stable so others could also install it simply from a deb file instead of compiling. If you are interested please drop me a mail. Oh, I forget that in the meantime I've changed it directly in the source file /src/preferences/preferences.h
cheers,
jazzmo
