New user on Mac Snow Leopard and having issues.
My 2 Cents Worth
Post by My 2 Cents Worth »
Hello;
I have been trying quite a few bit torrent programs lately. I am on a few different private trackers. I can't seem to keep a connection to my private trackers with Transmission or Utorrent without having to manually update the trackers all of the time. I really wanted to try Deluge but until they have an easy installer that will never happen for me. So today I found your client and downloaded it.
Here is my issues:
I had all of my torrents in a file called Torrent Seed on my hard drive.
-Transmission kept both the torrent file and the downloaded files in the same folder I had set up and did not alter them and it worked great for the most part other than dropping me from my private trackers every few hours.
-Utorrent did the same other than the fact it added [.something] to the end that I had to remove whenever I tried another client.
Each client I tried I set up to check that folder and use that folder for everything (Torrent Seed).
So when I set up your client the same way it worked just great except for the fact that I cannot find the [.torrent] files anywhere. I did a hard-drive search and cannot find them either.
If I want to switch back to another client I will need all of those [.torrent] files to seed so please help me find where they are.
My second issue is;
I love the way your client is set up and works however no-matter how I try and tweak the preferences I can't seem to get but only a small few torrents to upload at once. I am able to seed up to 3MBps with both Transmission and Utorrent and they will feed everyone of my torrent files at the same time I have 50 at the moment.
I am only able to get a fluctuation of between 3 and 8 torrent files at a time to connect with your client it doesn't matter if I limit their upload speeds or have them wide open it will only do a few at a time. They all say seeding and many peers are in the peer lists but only a few turn the main screen to orange on the line and seed.
Please Help.
