[Solved] qBittorrent crashes right at the start
asimcool
Post by asimcool »
Hi
I have been using Qbittorrent for about a month with no issues but since the morning today it has been crashing each time I try to start it.
The following is the error dump that comes up when I open the more details option in the error message:
Problem signature:
Problem Event Name: BEX
Application Name: qbittorrent.exe
Application Version: 0.0.0.0
Application Timestamp: 4dee894a
Fault Module Name: MSVCR90.dll
Fault Module Version: 9.0.30729.5570
Fault Module Timestamp: 4d2c14d2
Exception Offset: 0006ccd5
Exception Code: c0000417
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: d956
Additional Information 2: d9565f680224cde11a6ebc4ea2ed1432
Additional Information 3: 4b18
Additional Information 4: 4b18032f2aa3ea7f11feefd4eb3551e2
Havent faced this problem before. At the same time just to bring you up to speed I am using Windows 7 Ultimate updated with the latest SP which came out about a week ago.
Could someone help me please as I have a lot of unfinished torrents queued up there and don't want to lose that data.
Thanks.
ASIM
asimcool
Re: Qbittorrent crashes right at the start.
Post by asimcool »
Just to update I have downloaded the latest version and installed it but still the problem persists. (V 2.8.1)
ironcross
Post by ironcross »
This is fixed in 2.8.1.1 8-)
asimcool
Post by asimcool »
Thanks for the reply but thats the version I have. Checked again by redownloading and reinstalling.
Same problem.
ironcross
Post by ironcross »
Well, you said you have 2.8.1 and we all had crash problems with it, but this was fixed quickly in 2.8.1.1 :roll: So the last version is 2.8.1.1 and it's work correctly. I have no idea why it crashes on your mashine.
loki
Post by loki »
The error is a different module and error message than the 2.8.1 error message.
As an example, Yours:
And my 2.8.1 error:
Problem Event Name: APPCRASH
Fault Module Name: LIBEAY32.dll
Fault Module Version: 0.9.8.15
Also the dll version you have listed in your error log is different from mine in 2.8.1.1 install folder, mine shows 9.0.21022.8
asimcool
Post by asimcool »
Loki, any ideas on how I can solve this???
As I said in my first post got a lotta torrents unfinished in qbittorrent so really need that data...
Thanks both of you
ASIM
loki
Post by loki »
If you'd be willing to try my dll file, download it and place it in your install folder. Or, you may try waiting a few days for the official 2.8.2 windows build.
asimcool
Post by asimcool »
that sounds like a plan...cant mess it up more than it already is.
Can u mail it to me on [email protected]
Rgds.
ASIM
loki
Post by loki »
I sent you a PM if you didn't already get it.
asimcool
Post by asimcool »
Got it and tried it but no luck. :(.
Looks like I will have to wait for the new build to come out. Thanks Anyway. Appreciate your help.
loki
Post by loki »
The 2.8.2 is out, the new "official" build it seems, built by sledgehammer_999. I had problems with his in the past though, so maybe not any better in your current situation. I'll upload my entire qbittorrent install folder if you want to try that before updating to his 2.8.2. Just overwrite every file with my files. Or, just go ahead with the 2.8.2 and see if that solves it for you.
