[unofficial]qBittorrent git master builds: 3.2.0RC1_20150502_bf463d4
schnurlos
Re: [unofficial]qBittorrent git master builds: 3.2.0RC1_20150502_bf463d4
Post by schnurlos »
[quote="tekko"]
Those 6 are new for 3.2.0. That's why sledge is giving a week for translators to finish them before making the RC1 stable.
Hopefully.
There is a lot of new text for 3.2.0, not only this 6 phrases.
My thinking is that there is this text on Transifex but didn't find the way to the .exe
4COMM
Post by 4COMM »
[quote="Peter"]
You are right. Well, check the bugtracker at Github.
If there is no such request, and it's not in RC1, make a new ticket.
I'll let someone else already have an account do ;)
Thanks for your help
[quote="s4nder"]
QBT doesn't remember the sorting pattern anymore. I like to sort my torrents by name. After restarting there's still an up arrow on the name column header but torrents are arranged randomly. I have to click the column header twice to get them arranged by name again.
Can you give a screenshot showing this and at least the first 3 letters of the torrent names?
4COMM
Post by 4COMM »
tekko
Post by tekko »
[quote="sledgehammer_999"]
[quote="s4nder"]
I've seen this once in a while. Happens in older alphas too, but with status column. Even though it's set to be sorted in ascending/descending order, I've to click the column header once for the sorting to be "activated."
4COMM
Post by 4COMM »
I found another problem :
I'm currently a useful ethernet connection from my @ box and the tethering from my smartphone (fair use 4G).
Since I want to use my fair use to download with Qbittorent, I go into options and I select "wifi".
However I find that it doesn't work because when I want to view content on youtube for example,
the load is very long, proof that Qbittorent use all my internet connections available.
The reboot of applying change anything,
I've found this problem with the current version of Qbittorent.
Unless I'm mistaken in the option selection ? (Wifi hotspot for WiFi from my smartphone seems to me logical)
Did you restart qbt after you changed interface? What does the log say? (view->execution log)
4COMM
Post by 4COMM »
" The reboot of applying change anything, "  ;)
You should have changed the language to English when posting the log. I cannot read your language. But from what I can see it does connect to 192.168.43.113 interface. Is that the local IP of the wifi interface?
There is only way to be sure that qbt traffic goes through that interface: Use a network monitor tool to tell you if qbt sends traffic via the other interfaces too. Maybe your firewall has such info too.
4COMM
Post by 4COMM »
192.168.43.113 : dongle wifi (Lynksys) for recept hotspot wifi ( Smartphone ) 192.168.43.1
192.168.1.1 : Ethernet PC for recept @ from my box 192.168.1.254
Picture edited  :)
Can you confirm that the external IP that you get from the log is the one from your 4G connection and not the one from your @ box? (what is @ box?)
4COMM
Post by 4COMM »
If I keep my connection enabled only by my smartphone, I get this:
@box  :o : it's
@box and 4G are 2 different ISPs, right?
Does the "external ip" shown in the log match the (external)ip you get from your 4G?
bloodybunny
Post by bloodybunny »
[quote="4COMM"]
Here is your problem.
Maximum numbers of half open connection ... lower it to somethin like 20 or go even lower. Start from 30 and go down till the situation is acceptable. Depending on your connection speed/wifi device capability that number differs.
