Option to remove Labels and Trackers completely from the gui.
Magoo
Post by Magoo »
Ability to hide these 2 items from appearing  in the main program window.
Either something under "view" or advanced options.
Re: Option to remove Labels and Trackers completely from the gui.
Im also not using the labels and the tracker system. I know that they are both being used alot by others for sure but I like the way I manage my torrents without them :).
An option to remove them completely from the gui would be nice, but definitly not high priority in my opinion. Sledge may answer if it is possible or not.
Magoo
Post by Magoo »
I'm not using them either, so would be nice not to have them there to look at  all the time. :)
Just a thought  8)
tekko
Post by tekko »
For the record...
In addition to just show and hide, I've made a request for the ability to fully disable it.
https://github.com/qbittorrent/qBittorrent/issues/2985
I don't use the tracker filtering and always had it hidden.
I know the checkbox just show/hide the list, because there are still operations behind the scene. i.e. downloading of favicons.
If thats possible it would be good. I was thinking to open an issue about it also for Magoo.
Magoo
Post by Magoo »
If you could do that, that would be greatly appreciated :)
Hiding trackers: I am also interested.
The label thing is nice.
ciaobaby
Post by ciaobaby »
[quote="Peter"]
Uncheck the box(es) and only the checkbox (and header text)  will remain visible.
Ohohoho.. Well.  :-X
I didn't even check just went on the forums and thought, "that would be nice." :)
(I used the client mostly on Linux when I was testing translations, and I didn't even take a careful look around the client.)
ciaobaby
Post by ciaobaby »
As said earlier and in a different thread, we ALL possess and frequently use that one innate very human behaviour  :)
It's something about trees and wood :)
