Some time ago I ran chkdsk and it dismounted the volume my downloads are on while qBitTorrent was still running. Unfortunately it resulted in all my torrents saying "Missing files", even after restarting.
I did re-check the torrents and afterwards they show 100% and seed just fine until I restart qBitTorrent. Then they all become "Missing" again. Gah!
Is there a way to fix this?
How to fix "Missing files" after volume dismount?
Re: How to fix "Missing files" after volume dismount?
Shut down the client, mount the drive (make sure the location is the same), restart the client, Resume all tasks (Ctrl+Shift+S)
A recheck may be necessary but not usually.
