[unofficial]qBittorrent git master builds: 3.3.0alpha_20150621_5e400d31174
Link to latest: index.php/topic,3606.msg18331.html#msg18331
ORIGINAL POST BELOW
Here is a build of qBittorrent 3.3.0.alpha sha1 2e6c890883d from git master with:
boost 1.55
libtorrent 1.0.6git+d881d78a8
qt: 4.8.7
Built using msvc2013
Huge thank to glassez. He did a huge refactoring of the core code. You may experience a snappier interface and probably old issues may be fixed (eg temp folders).
Don't expect GUI changes.
Since all core was refactored something might have slipped. If you find something that worked in v3.2.0 but not in v3.3.0 please come to the bug tracker and report the regression.
Git changelog from last alpha: https://github.com/qbittorrent/qBittorr ... c4a2b2944e
BIG FAT WARNING
The v3.3.x series have a new saving system for torrent progress. It isn't backwards compatible with pre v3.3.0 versions. You'll be presented with a message box to migrate to the new system. If you continue there is not going back.
Not really
You can go back if first you go to the BT_backup folder and remove the trailing "dot number" from the fastresume names. This could break in future releases though.
Link 1: http://www.fosshub.com/qBittorrent.html
Link 2: http://builds.shiki.hu/qbittorrent_3.3. ... _setup.exe
Last edited by sledgehammer_999 on Mon Jul 13, 2015 9:58 pm, edited 1 time in total.
Matth78
Re: [unofficial]qBittorrent git master builds: 3.3.0alpha_20150621_2e6c890883d
Post by Matth78 »
Just installed last alpha => so far I noticed that on double clicking a torrent in Rss tab it does not show dialog to set download path. It does when adding torrent file directly from websites.
junpet
Post by junpet »
Disk space update still doesn't work.
http://i.imgur.com/kwvWeKV.gifv
And qBittorrent doesn't remember the layout on the RSS tab, always sets to default. (also exists in v3.2.0)
Wow nice, will install it when I get home.
Thanks sledge, special thanks to glassez for his work.
FliessendWasser
Post by FliessendWasser »
Nice to see for those who were eagerly waiting for a new version to try out!
So far, it's seeding my 21 torrents nicely, with the speeds I expect to have.
Also, I mirrored the alpha version, along with the current stable version both for Mac and Windows, on my webspace, to provide another possibility for those who want to download the program :)
Cheers!
Switeck
Post by Switeck »
Seems qBitTorrent v3.3.0 alpha has always announce to all trackers checked as its default setting.
Any chance qBitTorrent will start supporting tracker tiers?
http://wiki.depthstrike.com/index.php/P ... ltitracker
- Every newly added torrent is set to ''sequentally download'' by default. Need to uncheck it by every new torrent I add.
Fixed. I was migrating my torrents from BT_backup manually from 3.2.0 to 3.3.0 and only these torrents were automaticly set ''sequental download'' while at 0.0% before rechecking (all rechecked fine). Completely new torrents were not. Weird.
- Also the default settings (compared to 3.2.0) are different. Like half open connections is at 20, uploadslots settings are unchecked, queue is on by default.
Can someone confirm this.
Switeck
Post by Switeck »
20 half open connections shouldn't cause any issues. If someone is running 100's of torrents and need very quick start-ups, they can raise the amount. For everyone else, 20 is probably more than fast enough.
Yes, there doesn't seem to be an upload slot limit enabled by default. Be nice if global upload slots is not allowed to be greater than upload speed limit even if not selected.
And active torrent queue limits are set as well (3,3,5). Suitable for some "average" ADSL/cable users?
Upload Speed is limited to 50 KiB/s by default -- about 0.5 megabit/sec worth of upload bandwidth. Bound to only be a good fit for slower lines and/or lines that are shared by multiple users. Can be changed as needed, but many people won't know what to change it to.
Thanks for the information sledge.
I like the new changes alot :)!
tekko
Post by tekko »
I ran the old uninstaller and removed the old config files. Then I installed the new alpha with old bt_backup... All the removed trackers came back. Normal?
3.3.0a no longer freeze for a few seconds every few clicks.
I modified trackers and restarted qbt. Changes were reverted.
Tracker list starting with dht://******** get filtered into trackerless, even though there are http and udp trackers below.
All these problems due to the fact that I used my old bt_backup?
I tested the client offline just to be safe on xpsp3.
Please restore bug report and forum links under help...
https://github.com/qbittorrent/qBittorrent/issues/3274
I noticed the status filtering has changed a bit. I will do some testing when I have the time.
It would be more consistence if status "checking" sort before "completed" since other status filters have "checking" on the very top.
tekko
Post by tekko »
In my opinion, the alpha version should be updated more frequently, even with a fewer patches. The less bugs it has, the more likely people can use it instead of the stable version. The longer people can use it, the more thorough the testing would be. i.e. After a few tests, I would have to go back to the stable version due to the fact that I can't modify the trackers. Even though the alpha seems to have a smoother gui, I can't quite use it for everyday downloading/uploading.
junpet
Post by junpet »
I can't rename torrents.
Right click on a torrent > Rename... > Type new name > Click OK > Nothing happens
FliessendWasser
Have some problems with the numbers... Even though most torrents are paused, it begins with "2".
I can manually move it up, but if I add a torrent with no other torrents running, the added torrent has number 2.
Made a screenshot on how it's looking on my side. I guess the torrents I added don't play a big role, thus I somewhat censored them.
[FIXED]
Last edited by FliessendWasser on Mon Aug 10, 2015 11:16 am, edited 1 time in total.
Inwoods
Post by Inwoods »
Cannot seem to add or remove columns.  The UI input seems like it goes through, but the UI doesn't actually change.
Import brought the old columns configuration as far as checkboxes, but the default columns actually display.
Turns out two columns were obscenely wide after import, and the columns were updating correctly, just far outside the viewable window.
