Hello.
Where is the setting to configure Outgoing ports range located in configuration file? I'm running on Debian Linux with only Web interface available and can't find the option there.
Thank you.
Re: Outgoing ports range
Preferences/Advanced/OutgoingPortsMin
Preferences/Advanced/OutgoingPortsMax
Well there wouldn't given that you asked for the configuration file settings.
