[unofficial]qBittorrent git master builds: 3.3.0beta_20151109_c40bab05550
Re: [unofficial]qBittorrent git master builds: 3.3.0beta_20150804_f893131b8d0
[quote="Switeck"]If I click on the speed button and try to log say...Payload Overhead, qBT freezes up. 1 CPU core goes to 100% usage and seems to stay there.[/quote]Seems fixed as far as not crashing when doing this with the latest qBT 3.3.0 beta build.
Re: [unofficial]qBittorrent git master builds: 3.3.0beta_20151028_c75725e2d8c
Here is a build of qBittorrent 3.3.0beta sha1 c75725e2d8c from git master with:
boost 1.55
libtorrent 1.0.6(git 7db599babdf80a)
qt: 4.8.7
Built using msvc2013
Git changelog from last beta: https://github.com/qbittorrent/qBittorr ... 988a13ec68
BIG FAT WARNING
The v3.3.x series have a new saving system for torrent progress. It isn't backwards compatible with pre v3.3.0 versions. You'll be presented with a message box to migrate to the new system. If you continue there is not going back.
Not really
You can go back if first you go to the BT_backup folder and remove the trailing "dot number" from the fastresume names. This could break in future releases though.
Link 1: http://www.fosshub.com/qBittorrent.html
Link 2(only as fallback): http://builds.shiki.hu/qbittorrent_3.3. ... _setup.exe
boost 1.55
qt: 4.8.7
BIG FAT WARNING
Not really
Thanks for your quick responses, time and effort sledge.
- Member
AVAST! v2014.9.0.2018 (with definitions of today) detects a virus JS:ScriptIP-inf[Trj] in C:\Documents and Settings\[user]\Local Settings\Temp\qt_temp.FD4724 in process C:\Program Files\qBittorrent\qbittorrent.exe
using qbt v3.3.0beta 20151028 on WinXPSP3-32.
This did not appear on latest qbt v3.2.4 some days ago.
After adding an exception, it seems OK, but I don't like that (because I can only add the entire directory to exceptions). It seems I'm having difficulties to update AVAST! version right now, so I can't tell if newer versions do not detect this temp-file as 'positive'.
Yeah, avast constantly marks some of my installers as viruses. It is always a false positive.
Re: [unofficial]qBittorrent git master builds: 3.3.0beta_20151109_c40bab05550
Here is a build of qBittorrent 3.3.0beta sha1 c40bab05550 from git master with:
boost 1.55
libtorrent 1.0.7(git a10289afd6f)
qt: 4.8.7
Git changelog from last beta: https://github.com/qbittorrent/qBittorr ... 8c609dc076
BIG FAT WARNING
Not really
boost 1.55
qt: 4.8.7
BIG FAT WARNING
Not really
2 known issues:
1. successful listening interface log entries don't appear on launch -> fixed on master
2. opening and listening SSL port 4433 -> not fixed. comes from libtorrent.
Thanks sledge and the other guys at Github.
I was just wondering
Will v3.3.0 stable (and newer) be using Qt5 as default?
Im following Github also;
My intention is to make Qt5 the default if #2835 is resolved.
I assume this means yes?qt5 bugs: Probably fixable now and switch to qt5 by default.
It is highly probable that qt5 will be default now.
Is the new theme still planned for 3.3.0?
[quote="Ryrynz"]
What new theme?
What new theme?
RC is out. New forum topic started.
