linuxmint.com is on a cluster and the modified ISO was on just one of the servers in the download mirrors, rather than being on the primary.the word press server was the same server as linuxmint.com not shared credentials.
Trust me; with WordPress on a server it does NOT need to have any "shared credentials", to lay waste to the average or even slightly above average server security measures and if you add cPanel into the mix it makes the "crackers" task just a little bit easier. So if any of you run a Wordpress 'blog' on hosting that uses WHM/cPanel and the blog is fairly well known, I suggest that you install this plugin and at the very least use the "Security Scanner" to alert you if there are any files that have been modified since the previous scan
