WebUI won't save HTTPS certificate key
snakyjake
Post by snakyjake »
I'm trying to save the SSL key and certificate from the WebUI.  But QBT won't save it.  There are no error messages describing the problem using the WebUI.
[CAUSE]
The problem is generating the key/certificate using GENRSA.
GENRSA requires a password, and QBT won't accept the key/certificate.
[SOLUTION]
The solution is to generate a key/certificate using x509.
For more information:  Linux WebUI setting up HTTPS with self signed SSL certificates.  The steps need to be updated to reflect the above soultion.
ciaobaby
Re: WebUI won't save HTTPS certificate key
Post by ciaobaby »
client version?
have you tried with no certificate pass phrase
snakyjake
Post by snakyjake »
Client version:  Not sure.  It was the version before 3.2.3.  I just upgraded, but haven't tested.
By following the steps at the bottom of the instruction page, I created a no password x509 certificate.
