Download Problems
ooonowoo
Download Problems
Post by ooonowoo »
im new to this program but very familiar with computers, i cannot seem to get anything to download consistently, every time it starts, it will stop just as quickly and give me an I/O error message. im running windows 7.  can anyone help??? ive tried numerous different settings but nothing seems to give me a consistent download.  al my network connections are secure
loki
Re: DOWNLOAD PROBLEMS
Post by loki »
The current stable version has an error exactly as you describe with Windows 7 (64bit only, as far as we know). You'll have to go back to, at least, version 2.8.1.1... perhaps 2.7.3.
Also this should likely be in Windows section.
ironcross
Post by ironcross »
[quote="loki"]
Topic moved  ;)
v2.8.2 (current stable) works flawlessly with 32-bit but on the other side v2.7.3 works with 64-bit without problems at the moment. Its a known issue/bug and will be fixed as soon as possible. I just want to add; if you use v2.7.3 with 64-bit you ain't losing anything important (fixes and such, though it's always important but not very important things) from the current stable with 32-bit. v2.7.3 works just fine.
r4dic4l
Re: Download Problems
Post by r4dic4l »
i searched and downloaded v2.7.3 for win7 64 but i still get I/O errors for my downloads @@"
at first everything went smoothly, but soon, after the 3rd torrent those I/O errors start to appear....
Check out 2.8.3 ... it is supposedly fixed that problem.
s4nder
Post by s4nder »
2.8.3 isn't available for Windows yet, is it?
ironcross
Post by ironcross »
[quote="s4nder"]
Yes, not available yet. We must wait dib or sledgehammer to return.
