Ignore subsequent matches for: Add hours
GoodDaySir
Post by GoodDaySir »
Some of the shows come out daily and many times the minimum requirement of 1 days makes it so that it ignores the rss for the following day. If you could also add hours instead of days that would solve the problem
Re: Ignore subsequent matches for: Add hours
Welcome :),
If you want you can open a new issue at the Github page and our maintainer might take it into consideration.
(Im not using the RSS myself so can't judge how handy this would be or not)
