i think qBittorrent disconnect my internet connection(i use version 3.2.5)
ciaobaby
Re: i think qBittorrent disconnect my internet connection(i use version 3.2.5)
Post by ciaobaby »
Ebay, Amazon,
So long as the output voltage is the same as the original, (usually marked on the back) and the capacity (Amps or milli-Amps) is the same or greater, one of the multi-voltage PSUs that come equipped with several  adaptors will do.
menash
Post by menash »
[quote="ciaobaby"]
Ebay, Amazon,
you are great!
thank you very much.
ulupulu
Post by ulupulu »
exact same issue here. only happened recently
Tech101
Post by Tech101 »
menash wrote: Wed Nov 18, 2015 11:57 am i have tplink 1043ND router with openwrt on him, which connected to centurylink c1000a modem.
the 1043ND make the connection to the internet.
i have 2 linux OSes (Arch, gentoo), and in both of them(dualboot) the problem exist.
my connection's speed is 60 mbps download and 3 mbps upload.
Ever thought ur ISP is blocking P2P traffic???
