All torrents stall, even with new version
jukegrad
Post by jukegrad »
I am on iOS 10.9.5 running qBt 3.2.5. Original download and usage of qBT was fine. Then, all torrents went straight to Stalled. Doesn't matter which torrent. I did not change anything in the settings.
It's not my internet provider as my SO (on Windows) downloads files from the same locations without any problems at all.
Log is below. Any suggestions appreciated. Thank you.
11/20/15 11:55 AM - Embedded Tracker [OFF]
11/20/15 11:55 AM - Encryption support [ON]
11/20/15 11:55 AM - Local Peer Discovery support [ON]
11/20/15 11:55 AM - PeX support [ON]
11/20/15 11:55 AM - Anonymous mode [OFF]
11/20/15 11:55 AM - HTTP User-Agent is qBittorrent v3.2.5
11/20/15 11:55 AM - UPnP / NAT-PMP support [ON]
11/20/15 11:55 AM - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using NAT-PMP. external port: 8999
11/20/15 11:55 AM - External IP: 72.231.27.75
11/20/15 11:55 AM - qBittorrent failed listening on interface 0.0.0.0 port: UDP/8999. Reason: Address already in use
11/20/15 11:55 AM - qBittorrent is successfully listening on interface :: port: TCP/8999
11/20/15 11:55 AM - qBittorrent is successfully listening on interface 0.0.0.0 port: TCP/8999
11/20/15 11:55 AM - Options were saved successfully.
11/20/15 11:55 AM - '/Users/clr/Library/Application Support/qBittorrent/BT_backup/ea33ec4ef3a1d54a807e4f4e62fe24a8e41e5a3f.torrent' resumed. (fast resume)
11/20/15 11:55 AM - '/Users/clr/Library/Application Support/qBittorrent/BT_backup/4c53daa6fe8b25b75eb8487bb076fc71d25ab8a5.torrent' resumed. (fast resume)
11/20/15 11:55 AM - DHT support [ON]
11/20/15 11:55 AM - qBittorrent failed to listen on any interface port: 8999. Reason: Address already in use
11/20/15 11:55 AM - qBittorrent is trying to listen on any interface port: 8999
11/20/15 11:55 AM - Peer ID: -qB3250-
11/20/15 11:55 AM - qBittorrent v3.2.5 started
ciaobaby
Re: All torrents stall, even with new version
Post by ciaobaby »
Says you have two applications using the same port number on the same machine.
